1/24 London bus dio
1/24 London bus dio
Postby kpnuts » Fri Mar 03, 2017 5:41 pm
HI all here is one I've been working on for a while, as you can see the bus is done
It's going to have all British iconic vehicles in it, including a Dr who tardis.
Here are the cars for it (I've realised I didn't put the lotus in it) I think it's looking quite busy.
I would definitely buy the bus again it's a hell of a kit with loads of plastic and the fit is outstanding, my only gripe is some of the decals are too big (it's OK if you know beforehand but a real pain in the butt after you've applied it and have then to cut it to fit)
LiamD
Re: 1/24 London bus dio
Postby LiamD » Fri Mar 03, 2017 8:54 pm
Remember the CIE version very well. turned out very well.
'One of these days I will get my eye in'
Postby Vinny » Fri Mar 03, 2017 10:27 pm
That bus is one very impressive model! You certainly did that British icon justice. Great job and that diorama is going to be a something else!
Postby kpnuts » Sun Mar 05, 2017 6:17 pm
Hi all next update, started the London taxi, I must say I'm a bit disappointed (not the kit it's good enough) it's just I could have knocked it out in a day easily, it is a VERY simple kit, yes it looks like a London taxi but maybe if it had a full engine or maybe the door handles were separate parts, I don't know what they could have done but it really is a simple kit.The kit is rated skill level 3 personally I think it should be level 1.
Anyway I've also started the Italari phantom 2 rolls royce (I've spent the same amount of time on this so you can see the difference) the taxi only needs the glass and body on half an hour, let dry add decals done in 2 hrs
Postby kpnuts » Tue Mar 07, 2017 7:49 pm
Hi all well the taxi is finished (definitely not skill level 3 as the instructions suggest) I could easily done it in a day.
I did some more to the roller
Also started a paper model of a classic London Police box (never done a paper model before and it's a strughle)
Postby arni » Tue Mar 07, 2017 10:26 pm
Here's one for you,a Herald estate.....
Postby kpnuts » Tue Mar 07, 2017 10:35 pm
Who makes that kit, is it 1/24 or have you worked your magic on the Airfix 1/32 one
Postby arni » Wed Mar 08, 2017 6:50 pm
kpnuts wrote:Who makes that kit, is it 1/24 or have you worked your magic on the Airfix 1/32 one
Yes it is an Airfix 32nd converted into an estate. :lol:
Postby kpnuts » Wed Mar 08, 2017 7:50 pm
Well that's a great job you've done.
Postby kpnuts » Wed Mar 08, 2017 7:52 pm
Hi all well i didn't like mk1 so here's mk2
And here's the two together
Much happier.
Return to “Vehicle Dioramas”
