HS.125-600B Matchbox 1/72
Post your aircraft build topics here.
Sun Oct 29, 2017 11:48 am
I started this model a few weeks ago,so here's a few pics to bring ye up to date.It's the old Matchbox kit which first came out in 1974.It's basic in detail but shapewise pretty good,so I just had to put more detail on the model.Here's the sprueshot.
As usual with Matchbox kits the panel lines are pretty deep so I used Mr. Surfacer to fill them in,the door was glued in & then filled with green stuff putty & Mr. Surfacer since it had large gaps.I carved into the front of the rudder to give it a more realistic shape & done a little scribing on the rudder as well (more to do there).The trailing edge of the rudder & engine pylons were thinned down.I'll have to do a bit of scratchbuilding for the cockpit but won't go mad as not much will be seen.Added some liquid gravity in the radome with watered down white glue.
Quick decal test done.Just warm water used & they are fragile.You can see the bottom of the decal started to crumble as I pressed it on the kit to remove some water.I'm no decal expert but the glue has done it's job.
I glued in the fillet at the wing train edge/fuselage join (still needs tidying up),drilled for a light before the wing,cut out the wings & filled in panel lines & sink marks,main undercarriage doors,glazing (will need to thin remove the framing on the cockpit) & finally I removed the elevators.I scratched new elevators from 2mm card since I thought it would be easier than cutting into the Matchbox tailplanes.
The photo shows the underside loosely fitted.
I'll do something simular with the ailerons soon.The wings have a droop towards the tips & thinking back to my first Matchbox 125 - that also had the same droopy wings.I had a quick look at another 125 build & that also has the droop so I think it comes down to the sprue design.When the parts are cut from the sprue the wing parts will bend into this curve.I tried dipping the wings in warm water to help straighten them but was only a little successful so I tried fitting some brass rod in the wing to help straighten it.Not so good when I almost went through the wing with the power tool.
A little more detail on the tailplane.
Also on the tail & rudder.
So that's it till I get more done & photos.
Sun Oct 29, 2017 3:00 pm
love the old multicolour matchbox kits
you could always try giving the decal sheet a waft over with varnish, might hold them together long enough to bed down
Tue Oct 31, 2017 6:43 pm
Horray!! Finally a Flipping Aeroplane :)
Nice one man, Gold is on the way :)
Tue Oct 31, 2017 9:22 pm
Jeez your right George,been a while since I built a plane on here.Don't know about Gold - once it's not a Whistlin Gold Finger I'll be happy man.
Tue Oct 31, 2017 9:28 pm
Cheers Beowolf for the tip.I won't be using the kit decals,just tried them out to see if they were still useable.I'll build this as an Irish 125.
Sun Nov 26, 2017 8:26 pm
I cut out the ailerons & began making new ones from 2mm plastic sheet.
I cut out a little too tight on the bottom one - no worries.Both were then sanded to shape.
I added a little plastic sheet in two positions to make the aileron the correct size,then shaped.
The landing lights in the wings were just a panel line so I tried to improve them.
So I cut out the panel & thinned the surrounding plastic inside the wing.Then cut some lengths of plastic strip & glued them to the inside protruding into the opened area.The idea is this will give a lip of plastic strip onto which the clear plastic light cover will be attached.If it works out - great.
Then the internal walls of the light fittings were built up & glued onto one half of each wing along with a scratched taxi light from clear sprue & a landing light from Little Cars 2mm clear lens.
It looks a little rough but it will work out fine,painted with Vallejo white & a little beige where the white chipped off.
Little Cars 1mm clear lenses were glued into the holes drilled in the fuselage sides ahead of the wings & the hole was then filled with superglue (to be sanded back flat) to make the lights glass cover.Also the kit wingtip lights were cut off & clear plastic glued in their place to be sanded to shape.I used a clear plastic knife as the donor.They were drilled & painted red & blue to represent the coloured bulbs.
Here's a photo of the ailerons as they are at the moment marked out for a little more detailing.I forgot I also thinned down the trailing edge of the flaps & took a skim off the top.The navigation lights have been blended into the tips with a file & a fine sanding stick.The lights in the side of the fuselage were also sanded flat with sanding sticks.
Finally the tailplane bullet fairing got a bit of Milliput to extend & shape it & then a coat of Mr. Surfacer (still a bit to do).The hinge areas were built up a little & shaped with Mr. Surfacer as well.
Ok,here's my attempt at straightening the wings.I already cut a grouve on the inside of the wing and cut some brass tube & taped this onto the top wing section.
Then added a little araldite epoxy glue.
Covered that with a little cling film so it doesn't glue to the other half of the wing.
Placed the other half of the wing on & pressed onto a steel ruler so it sets flat.I earlier removed a strake from the bottom of the wing which wasn't on this 125-600.It was then left overnight.
Till next time,
Anon....
Mon Nov 27, 2017 2:57 am
The lengths we go to to get them right. Fair dues to you. :o)b
Wed Nov 29, 2017 11:36 am
nice one quinny, Some effort these m8
Wed Dec 27, 2017 1:28 am
Cheers lads,tis a bit of a slog alright.
Not been doing much modelling just a little now & again - nothing worth posting about.Right so what has been done?
I used a Radu scriber to scratch some detail in the flaps top & bottom but it looked a little overdone so I gave it a coat of Mr.Surfacer later to blend it in more.
The tailplane/elevator area was tidied up to narrow gaps,the bullet fairing was shaped & the end tip cut down for a clear sprue light (not fitted yet),some wire was bent & glued to the front of the tailplane for the HF aerial to pass through.The ailerons were also tidied up for a better fit & a small intake was cut into the bottom of each wing along with a little scribing.I started on the cockpit area by cutting down the kit seats to shape,added armrests from strips of plastic,seatbelts from wine foil,Mr. Surfacer brushed on the seats & stippled as it dried to give the sheepskin effect.Centre console made from strip plastic & all painted with Vallejo acrylics in 1970's fashionable cockpit colour.Control columns are being made from strip plastic & bent wire.
I scribed new panel lines above the wings & lower rear fuselage.I was holding off on doing this waiting for some dymo tape in the post which never came in the end so it was scribed using Tamiya tape as a guide instead.Not great in places so it will have to be cleaned up a bit.The emergency exit was also scribed.
I was tempted to do a little detailing in the cabin & filled in a little bit with left over Milliput & plastic strip but very little would be seen,so I decided to just paint a few colourful shapes inside with Vallejo acrylics.Just waiting to finish with the simplified cockpit (again not much will be seen) & the fuselage can be closed.
Cheers for looking lads,
Thu Jan 04, 2018 2:21 am
Another update on the 125 - I added some shutters on one side after glueing in the cabin windows.You really can't see any detail through the glazing but your idea gives it something to catch the eye when finished.
I also finished the control columns (one slightly larger than the other but again not much will be seen I guess).Central console got a few details & paint.I also added some more fuselage detail using Mr. Surfacer.
I glued in a strip on plastic for the cockpit coaming so I only have the instrument panel to make & the fuselage can be closed up.I used some left over Milliput to fill in the air intake on top of the fuselage for the air conditioning & heat exchangers.A few lumps n bumps were made for the wings - topside before the flaps 3 bumps sanded to shape from plastic strip,the aileron hinges were shaped from white Milliput. Lower wing aileron hinges same as the top,still more bumps to do underneath. The windscreen got a rub of micromesh to remove the panel lines except for the centre panel line & it got a dip in Klear.Finally I glued the top of the fin onto the tailplanes & filled the gap with Perfect Plastic Putty & smoothed it with a damp paintbrush.
Adios,
Anon....
