Bristol Beaufighter Mk.VI TAMIYA 1:48
Post your aircraft build topics here.
ripper1
Re: Bristol Beaufighter Mk.VI TAMIYA 1:48
Postby ripper1 » Thu Aug 31, 2017 6:52 pm
It is time to put the individual parts together, the model begins to remind Beaufighter
I corrected the landing lights I think they look a lot better now
I still have to close the upper and lower fuselage connections because in the real plane these were uniform sheets of sheet metal. CA glue is perfect for this
Postby Georgeconna » Thu Aug 31, 2017 7:00 pm
blimey did you rivet the whole plane as well, some amount of work gone into this one bud.
ripper1
Postby ripper1 » Thu Aug 31, 2017 7:11 pm
When the glue dries and hardens, I polish the surfaces and apply a rivet grate. This will be the riveting end. Black tape protects the surface already done.
ripper1
Postby ripper1 » Mon Sep 04, 2017 5:42 pm
And ready. Finally the end of riveting.
mentioned rivet net in the vicinity of the cockpit
Finally I begin to fold all the parts and slowly prepare model to painting.
Unfortunately, it will take some time because I ordered a mask to painting and chassis niche from Brasin.
I hope that I will be able to show the results of the work soon.
ripper1
Postby ripper1 » Tue Oct 24, 2017 4:19 pm
Welcome again after a long break. I finally received the ordered parts and I can start working on the model. On the attached picture you can see the model prepared to cover the surface primer.
They will notice that the air intakes for the compressors have been changed. I noticed my mistake while looking at the pictures and luckily managed to make a change.
Using the new parts, I also improved the chassis and applied resin flaps that look much better. I rescinded the replacement of the chassis cavity for resin because it was too risky to damage the model.
The whole model has been covered with Black Primer with Ammo Mig and for the moment is presented so.
Postby Vinny » Fri Oct 27, 2017 12:10 am
Outstanding work :DX The rivets look smashing!
Looking forward to the next update!
ripper1
Postby ripper1 » Fri Oct 27, 2017 12:30 pm
Thannks :)
Part of the model was coated with MrHobby C8 varnish as a backdrop for future abrasions
now Chipping fluid and MrHobby H12. Next? Normal brush and water and fear not to wipe too much.
On the bottom of the model I placed postshading
for me it looks good It's still a bit of work on this bottom
I think I've finally finished the wheels
Postby d_anonymous_modeller » Sun Oct 29, 2017 10:55 am
She's looking fab Ripper.
Anon..
ripper1
Postby ripper1 » Mon Oct 30, 2017 4:25 pm
Uneven fight with black color:
postshading:
chipping:
and finaly preliminary corrections of both:
sorry for the quality of pictures but made on fast phone :oops:
ripper1
Postby ripper1 » Fri Nov 03, 2017 3:56 pm
I think it's all for the moment.
The model is ready to be covered with clear varnish and then I will apply decals
black color applied multilayer: airbrush - various shades, sponge - also different shades, pigments and again airbrush
The effect in the real world is satisfactory, unfortunately the pictures do not show up well.
exhaust pipes a little valorised:
After the decals are applied, there is still a lot of work to do when painting. This time will work oil paints and pastels, what will be the effect? Time will tell
