Bristol Beaufighter Mk.VI TAMIYA 1:48
Post your aircraft build topics here.
ripper1
Postby ripper1 » Tue Aug 08, 2017 1:16 pm
In the presentation I mentioned that I am currently working on the aircraft model mentioned in the title. I said I'll try to present a workshop and so here it is. This is probably known to everyone TAMIYA model:
I want to build the plane shown below:
I have dealt with the interior quite quickly in total and so little will be visible from this in the finished model:
Then I closed the fuselage:
Re: Bristol Beaufighter Mk.VI TAMIYA 1:48
Postby d_anonymous_modeller » Tue Aug 08, 2017 10:18 pm
Hi Ripper,
nice progress there.Its a pity the interior detail will be hiddenI look forward to the rest of your build.
ripper1
Postby ripper1 » Wed Aug 09, 2017 1:21 pm
Because TAMIYA offers a model with raised ballasts and the plane I was building had a perpendicular defect, it was necessary to intervene with the saw:
After grinding and gluing I fixed the corrected ballasts to the fuselage. Then I riveted and left for further work.
At this stage I also removed the very ugly daggers of the aileron trimmers. It will replace it with metal parts later.
ripper1
Postby ripper1 » Sat Aug 12, 2017 3:48 pm
I further decided to make the TAMIYA product for the Bristol engine:
Drills and bits of wires went in motion:
underlay
Painting MrColor C8 and weathering - TAMIYA panel liner
The complex engine presents itself much better than before
I also painted the propeller (C8, Chipping Fluid, TAMIYA XF-1,brush with water, XF-1 filter and finally the pigments). The whole thing so far satisfies me
Postby Lego » Sat Aug 12, 2017 9:39 pm
That's very nice work.
Keep them coming.
ripper1
Postby ripper1 » Sat Aug 12, 2017 10:11 pm
thanks I try to :-)
ripper1
Postby ripper1 » Tue Aug 15, 2017 2:48 pm
I tried to improve the look of the chassis by adding some wires
Rear wheel painted but I'm not happy with its appearance I guess I have to do something about it
Postby Vinny » Thu Aug 17, 2017 10:17 pm
Superb modelling Marek [smilie=thumbsup02.gif] Your attention to detail is commendable :DX
Looking forward to the next update.
ripper1
Postby ripper1 » Fri Aug 18, 2017 4:54 pm
It was time for wings. Comparing the model to the plans listed in No. 75 of Air Monograph AJ-PRESS I found that the model is pure SF. So I had to work on a putty and carve out new lines and inspection panels.
Effect on the photos below. They also show that one row of rifle holes from rifles was removed because the plane I was building had only one row.
The removed canvas lines shown in the photos are as white lines. As you can see, I also marked the lines of rivets.
ripper1
Postby ripper1 » Mon Aug 28, 2017 7:11 pm
A few details.
I glued the oil coolers on the wings unfortunately look like this:
And they look like this:
So again I had to use a putty
As I wrote earlier, I decided to improve the rear wheel of the chassis. Unfortunately, two days of work with a needle and scalpel were wasted for a moment of inattention:
The wheel was glued but I'm not sure if it will maintain the weight of the model
