TBF Avenger at Midway
tsweeney
Postby tsweeney » Mon Nov 07, 2016 9:26 pm
The Grumman TBF Avenger (designated TBM for aircraft manufactured by General Motors) was a torpedo bomber developed initially for the United States Navy and Marine Corps, and eventually used by several air and naval aviation services around the world.
The Avenger entered U.S. service in 1942, and first saw action during the Battle of Midway. Despite the loss of five of the six Avengers on its combat debut, it survived in service to become one of the outstanding torpedo bombers of World War II. Greatly modified after the war, it remained in use until the 1960s.
Battle damage on the Avenger and the attack
Thanks for looking
Re: TBF Avenger at Midway
Postby Georgeconna » Wed Nov 09, 2016 10:29 am
What a Fab dio Terrance. Looks Fab, Did you use Resin for the Water?
Postby BrIAN332 » Wed Nov 09, 2016 10:06 pm
Brilliant work Tom, love the explosion and the water is excellent, keep up the good work :DX
Postby Vinny » Thu Nov 10, 2016 10:01 pm
Fantastic display Tom! :DX Really like the battle damage on the plane and the explosion is very effective. What did you use for that?
Thanks for posting and keep up the great work!
Postby jaydee » Tue Nov 22, 2016 2:11 am
I like it a lot, great idea great result. :o)b
tsweeney
Postby tsweeney » Fri Dec 02, 2016 8:34 pm
Vinny I took a wire clothes hanger and cut off the bottom One end into the plane and the other end into the torpedo. I then took plastic spruce from the model kit and cut then various sizes , then used wire to go around the hanger and spuce then using a hot glue gun I put the pieces in to form some kind of explosion, finally I used silacone caulking and covered the entire piece and added strands of cotton . the base was E-Z water when heated forms a resin the torpedo end went into the resin when harden and set I drilled a hole into the end of the plane far enough that the other end of the hanger went into the plane so that the plane looked level. If you have any other questions plese feel free to contact me.
Postby d_anonymous_modeller » Sun Dec 04, 2016 8:06 pm
Very nicely done Tom this looks mighty.
Postby jaydee » Fri Feb 10, 2017 11:00 pm
Don't be put off by lack of comment Tom, if you look at other work on the site it's only a few who do anyway. :o)b
Return to “Dioramas”
