Warspite gets a few scars
Postby kpnuts » Thu Jan 26, 2017 8:53 pm
Hi all this is one I finished about 3yrs ago hope you like it, the ship is Academy's 1/350 warspite it's a lovely kit and the fit of parts is up to tamiya standards.
Re: Warspite gets a few scars
Postby Spud » Thu Jan 26, 2017 10:09 pm
that is frigging Cool.
Wouter
Postby Wouter » Fri Jan 27, 2017 4:48 pm
very cool! How did you do those explosions?
You can't model properly without boozing Duvel, :D
Scanlan
Postby Scanlan » Sat Jan 28, 2017 12:58 am
That is just amazing, such an ambitious project perfectly executed...stunning.
Postby kpnuts » Sat Jan 28, 2017 7:08 pm
I got some leds (they're dirt cheap) you just need to know the forward voltage, which is usually between 1.8 - 3.3 (these were 3.2)(the long leg is the positive and the short is the negative)
If your going to have more than one led you could use (the led array wizard)(google it, it's free)
It's what I used for this dio you put in your source voltage and how many leds and it shows how to wire it up and whatever resistors you need.
So to the dio I glued the led to the cut off wing.
Covered it with glue from a hot glue gun (make sure you paint the led legs as the glue conducts electricity)(don't ask how I know)
Then painted it with oranges and yellows
Then covered it with cotton wool
I then sprayed it with brown grey an black using a swirling motion, and ended up with this.
Postby Vinny » Fri Feb 03, 2017 10:38 pm
Nice!! That's fantastic! Thanks for the little demo on the explosions... very convincing :DX
Cheers!
Postby jaydee » Sat Feb 04, 2017 1:18 am
That's inspiring work, great dramatic effect. [smilie=thumb.gif]
Postby JayCub » Tue Feb 07, 2017 8:58 pm
love it really brings modelling to life, thanks for tips
