Chinese six rat rod.
Fri Dec 08, 2017 2:29 pm
Going to be doing a chinese 6 rat rod!...
Anyone not familiar with a chinese 6 layout? it is two steer axles and (usually) one drive axle.
So I have to make a new chassis - on it's way,and use two identical front axles - - got two kits so one can be robbed.Both kits have a choice of straight or dropped axle,the engine well I have a choice - a diesel or a 1500 ci V12...methinks it will be the 12!!!
She is having a mild roof chop.
With the fabric centre removed.
more soon.
Fri Dec 08, 2017 7:28 pm
Just a quick mockup with the Rolls Royce Merlin engine - aprox 27 litres or 1650 ci..
https://en.wikipedia.org/wiki/Rolls-Royce_Merlin
Just read that the engine weighed 1640 lbs!
Sat Dec 09, 2017 2:18 pm
It snowed overnight so perhaps the slicks are a bad idea!!
This is the transmission that will be used.
Dressed up what if style with water pump,starter etc,plus valve covers.
A comparison with the Bugatti straight 8.
The aprox position I want..
And primed.
Sat Dec 09, 2017 3:59 pm
Sprayed the wheels silver.
Mockup...
Sun Dec 10, 2017 2:31 pm
Got the engine sprayed gold,the pipe are being cut down a bit.
The plastruct has arrived,it is 4.5x5mm and just right for sleeving the original chassis.Also the orig floor is being cut out.
Just to give you an idea on the lengthening.
What I am aiming for.....
Sun Dec 10, 2017 9:57 pm
Note to self,what about rear duallies?
Mon Dec 11, 2017 2:32 pm
Molotowed the tranny and Rolls Royce badges on the valve covers.
In place along with the grille shell.
The part ERTL part Plastruct chassis.
Thinking of the dually idea,the fronts will be ok with 500 lbs per wheel.
Mon Dec 11, 2017 6:33 pm
Thought I would show the bird the engine came out of.
The roof is on now,tomorrow it can be sanded down and the centre removed.
As she is...
Tue Dec 12, 2017 2:44 pm
Been goofing around with turbos (need 1 more - on order!)
Also experimenting with the wheels HONEST OPINNIONS please..
Got the shell primed,so next is roof centre out and some salt...
Wed Dec 13, 2017 2:10 pm
Going through the decals I discovered two sheets.(stuck together but mint!)
Opened the roof last night,got some salt on the primer today.
You can see by this how much the roof has been chopped by.
Then some flat green - US or IJN not sure now....
Followed by more salt..
Followed by another colour,will do that in a few hours.
