Pocher 1/4 ducati panigale
Re: Pocher 1/4 ducati panigale
Postby kpnuts » Tue Nov 14, 2017 8:27 pm
Hi all well I've finished the tank and sprayed the clear coat on the rest of the paintwork.
Such a gorgeous colour (even if I do say so myself)
Postby Spud » Thu Nov 16, 2017 5:23 pm
Christ thats some Kit!!!!!!!!!!!
Postby kpnuts » Thu Nov 16, 2017 8:18 pm
Hi all started adding detail to the starter relay.
Postby Vinny » Thu Nov 16, 2017 11:53 pm
Nice job one the paint but you're going to have to be very, very careful removing it from the sprue trees so that you don't damage all that good work. Any reason why you decided to paint the parts while connected to the trees?
I'm enjoying the progress with this one.
Postby kpnuts » Fri Nov 17, 2017 6:29 am
Hi mate it's how poacher did it and I love the fact the clear plastic packing it can in is very cleverly designed that no part of the painted surface is touching anything when it's in the packaging so I can store it with no worry of damage.
Postby kpnuts » Fri Nov 17, 2017 8:06 pm
Hi all well I've detailed up the battery and added the upgrade kit decal (the smaller decal is the one that came with the kit.
I must say I am surprised with a kit of this size and price of the huge amount of missing detail, mostly seems to be wiring which surely wouldn't be that expensive to add to the kit.
Postby kpnuts » Sat Nov 18, 2017 6:39 pm
Hi all started on the fuel system added the butterfly valves made from aluminium foil onto which I put brass leaf.
Then I cut it to fit
Then cut a piece of sprue then halved it.
Covered it with the brass leaf then drilled two holes and added a couple of screws
Postby kpnuts » Sun Nov 19, 2017 8:30 pm
Hi all bit more added here (this is just the supplied detail loads of wiring and connectors still to add) ( I really don't know why they don't supply varying thicknesses of wire surly it wouldn't add more than a tenner to the cost of the kit)
As I said loads more detail to add but couldn't resist trying it on the engine.
Also got the tyres on the wheels (Man they are heavy, but great quality)
Postby kpnuts » Mon Nov 20, 2017 7:13 pm
Hi all well here's the wiring added to the intake system and said system added to the engine (this thing is getting heavey)
