Airbrushing Essentials
Wayne E
Re: Airbrushing Essentials
Postby Wayne E » Wed Jul 29, 2015 12:01 am
Here is a hand tutorial if your ever wondering what airbrush to buy and why
really excellent !
Postby Vinny » Thu Jul 30, 2015 10:16 pm
Very interesting! :o)b
Postby jaydee » Sun Aug 09, 2015 2:04 am
On the ball Wayne, I like this guy,clever,funny and to the point.My eyes didn`t glaze over within seconds from the usual data overload. :o)b
Don Foley
Postby Don Foley » Wed Sep 07, 2016 2:00 am
Hi All,
Lots of very useful info on this thread but can I just ask what is currently believed to be the best compressor to buy?
Don.
Postby martay » Fri Sep 09, 2016 10:33 pm
Lots to choose from but deffo try to get an oil filled silent one with a reservoir tank, you can add bits and pieces on also, i stuck 3 water traps onto mine and a pressure adapter, the fittings on most are universal, so if you get a compressor you can add the expansion tank, you can put traps between the compressor and the tank and then after the tank as well and the put a pressure adjuster after the tank which will allow you to adjust the flow. Find a place that does air compressors of all types they will have the fittings it not hard and any reasonable compressor when matted to a tank with the rest of the bits will give a nice steady flow and no water vapor ingress in the airflow. The better compressor you get the more pressure it will put in the expansion tank and the more consistent flow you will get without pulsing on longer runs with the brush, hope that helps.
Postby martay » Fri Sep 09, 2016 10:36 pm
Also great video Wayne nice share cheers [smilie=thumb.gif]
Don Foley
Postby Don Foley » Sat Sep 10, 2016 10:15 am
Thanks Martay.
